You should change R,W,P for one of the two tools.
You shouldn't use external links for pictures, use upload function of the forum.
Menu > Setup > Frames. If tool frames is not active, hit Prev, then [Other] and select "tool." Select the tool frame you want to change, hit "detail," then "[Method]," select "direct entry," and change the appropriate WPR rotation to get the right orientation.
