I recently built a mobile, military robot optimized for use in desert environments which can be controlled remotely or autonomously and can collect/ stream video to a VR headset via its front mounted camera. The method of movement is a continuous track, created using steel roller chain connected by fasteners with 3D printed links. These loops sit on a custom designed drive sprocket and idler sprocket with 4 shock absorber loaded roller pins that act as the suspension system.
See the video here: https://youtu.be/5bgXjKqfwAk
Thank you!
