Fanuc Grease Change Question
  • AutoMattic21
  • May 27, 2021 at 2:22 PM
  • AutoMattic21
    47
    Hello all,
    We've just completed a grease change on a group of 4 ArcMate 100ic's. We are currently preforming the procedure to release remaining pressure from the grease bath and have noticed that the outlet on Axis 1 have been pretty consistently spewing grease out for the entire 10 minutes we ran axis 1 60 degrees at 100% OVR.
    Just wondering if this is normal?
    It seems like a waste of grease, but as this is a used cell, I'm wondering if maybe the last group overfilled the grease, and even though we only added grease until clean grease was coming out of the outlet, the axis could be over filled and thats why we're seeing so much excess grease during this procedure.
    If anyone has any more insight to this that'd be great. I'm not sure if we should keep running the releasing program until grease stops spewing, or if this is perfectly okay.
    Thanks,
  • pdl
    266
    1,504
    • May 27, 2021 at 2:56 PM
    • Best Answer
    Keep running it until it stops spewing grease. Your guess about it not being done properly last time is probably correct.
    It may seem wasteful, but VigoGrease is way cheaper than a reducer or the downtime that a replacement may cost.
  • AutoMattic21
    47
    • May 27, 2021 at 4:17 PM
    Quote from pdl
    thanks for this. I ran it about twice as long as it asked for and it stopped spewing. Sounds like everything else is good, and the other axes seem to be better.
    Thanks again
  • Skooter
    167
    2,002
    • May 28, 2021 at 12:45 AM
    There always seems to be extra pressure built up in axis J1 if you grease without moving the axis. If you slowly move J1 while greasing (preferred), very little comes out afterwards.
Similar Threads
  • fanuc arcmate 100 j1 axis joint/reducer repair
    • erik b
    • April 19, 2017 at 4:26 PM
    • Fanuc Robot Forum
