I have been working on a motoman using shifts they work alright but the moment you stop the program or step back it will lose its shift and I can’t figure out why.
Yaskawa motoman dx100 shifting
- AnthonyZ
- Thread is Unresolved
There are different types of shifts available. Which one are you using?
I am using the basic shift on
SFTON and SFTOF only work with Play or INTERLOCK+TEST START in Teach. You can't use the FWD/BWD keys by default setting to activate these commands. So if you do stop the program in the middle after a SFTON, use INTERLOCK+TEST START to finish it.
Not sure which generation controller you are working on, but the SFTON/SFTOF functions works pretty much the same from NX100 through YRC1000.
Best of luck
Interlock + Fwd should work. But what the OP is saying is the at any time you move the cursor either up or down a line or lines, the shift is thrown out the window. That has bitten me quite a few times. About a month ago I spent extra HOURS checking a program because I had to touch up the unshifted positions, and then start running the program all over again from the beginning. Not fun.
There is a Yaskawa parameter for that. The SFTON will only be canceled by the SFTOF.
That is interesting to know. We have DX100 and DX200. Do you have that parameter readily available?
Yes and we have contacted motoman and they gave us different parameters to try and none of them worked
What we do is it will track the shift at first but say we needed to go back a step it would lose the shift but we were still in the shift block
