Loading .PC file to robot
  • Hi,
    I have a LR Mate 200ic/5L with an R-30iA Mate controller.
    I made a backup of the robot and created a new workcell in handling pro.
    I was modified a kl file that we had, and compiled it in handling pro to get a .PC file. When i tried to load the .PC file in the controller, it said that it's loaded but i can't find it in the program list when i press [SELECT].
    I'm new to fanuc robot and i can't find anywhere what's the problem.
    Edit: I do have R632 and R567 option in the controller
  • Hmm, how did you load the program to the robot? Did you do it over the network by exporting in Roboguide? Or did you copy to a USB drive and then load on the robot?
    I'm using a CompactFlash SD card (see attached jpg).
    When i'm in the file menu, i press [UTIL]->[Set Device]->[Mem Device (MC:)] to access the content.
    I can see the pc file and load it, but it's not showing anywhere else.
  • Ok,
    One of my collegue just found the problem, I changed the name of the file but not the name of the program in the file, so i was just overwriting the old already existing program :S.
