Kuka krc1
  • SkyeFire
    Approved the thread.
  • Here are some pictures if you need anything else tell me
    Or you could READ FIRST. It's at the top of the forum for a reason.
    Here's a hint: instead of posting a bunch of fuzzy photos of the pendant, actually write a list of the error messages (with the actual error codes).
    2nd hint: ignore all the compile errors to start with. Hit ACK ALL, and see what errors remain afterward. Those are the ones you need to focus on first.
  • Or you could READ FIRST. It's at the top of the forum for a reason.
    Okay will do so thanks
  • Here are the errors left
    1- configuration error I/O driver INTERBUS
    2- more than one calibration file available.
    3- set robot number program robot name.
    4- motor temperature E1
  • please read pinned topic READ FIRST
    if you want help you need to provide details. one of the first things is the KSS version.
    you can comment out fieldbus drivers that is no longer used, simply edit IOSYS.INI and place semicolon in front of the line with driver (in this case interbus).
    make sure to remove calibration files for other robots. there should be only one and match serial number of the robot arm.
    make sure that robot is connected to controller (and using correct cables). without this robot will not be detected.
    connect motor to E1 or remove E1 from robot configuration.
  • Thanks for your reply sorry am bit noob to this where I can find the kss version and how to edit the IOSYS.INI
    if you read pinned topic READ FIRST you will find out...
    you can also try searching for IOSYS.INI, this has been discussed many times.
    making hdd image is a good idea. but this is much bigger than the archive.
  • if you read pinned topic READ FIRST you will find out...
    Okay I will do so thanks and sorry for the hassle
