Hello everyone,
Im working on a sealing robot, I wanna make a PLC test so I need "Open Applicator" signal when I use Dry Run signal.
Is it possible ? If it is, how can I make that happen ?
KRC 4 - GlueTech (V4.2.11)
Hello everyone,
"KRC4" provides no critical details. Are you using a KUKA dispensing option? If so, which one? What version?
Yeah my bad. Im using GlueTech (V4.2.11) if that helps..
He means KSS version too...
did you read the manual? when running program in T1, nozzle is always closed.
also there is a bunch of I/Os that can be configured
Well, all I need was to send "Open Applicator" Output to PLC when GlueOn and GlueOFF in T1. Well, I added these beneath Glue_UserBegin() and GLUE_UserFinish() in glue.src then it worked;
Glue_UserBegin()
Else
TRIGGER WHEN PATH=T_DISTANCE DELAY=0 DO BeginUp(GlueActData.SystemNo,GlueActData.DISP_GUN) PRIO=-1
ENDIF
GLUE_UserFinish()
Else
TRIGGER WHEN PATH=T_DISTANCE DELAY=0 DO OpenSysGun(GlueActData.SystemNo,GlueActData.DISP_GUN,FALSE) PRIO=-1
ENDIF
