Call a program using SR and BG logic
  • Theo.g
  • May 4, 2021 at 2:32 PM
  • Theo.g
    27
    • July 5, 2021 at 4:46 PM
    • #21
    Hello Fabian,
    Thanks for your reply,
    For information I can't change the CNT because, after this point I take a picture from a camera that is attached to the robot flange. However I will try to slow it down and I will let you know.
  • Theo.g
    27
    • July 5, 2021 at 5:24 PM
    • #22
    Ok, so I tried slowing it down and even increase the CNT (for testing) but it didn't change, I have the same message 'Over payload change distance' and the same stop.
  • Theo.g
    27
    • July 5, 2021 at 5:28 PM
    • #23
  • Fabian Munoz
    133
    Articles
    1,517
    • July 5, 2021 at 6:20 PM
    • #24
    Looking at the error
    ErrorSeverityMessageCauseRemedy
    R30BP:SYST-324Payload number is changedWhen the payload change distance of Collaborative Robot is disabled, the payload number has been changed.You can avoid to pause a program to change the payload number when the payload change distance is enabled.
    I don't have a cobot, but the payload variables on a regular robot are $PLST. Maybe you can find the variable to disable it
    Retired but still helping
  • Theo.g
    27
    • July 6, 2021 at 10:28 AM
    • #25
    Hi Fabian thanks for your information,
    I do have $PLST variables (see the atachment) but I didn't find anything like 'Payload change distance'.
  • Theo.g
    27
    • July 6, 2021 at 10:32 AM
    • #26
    Bu as you can see (I hope), I have a variable named $PLST_OVLD that I thought was probably the meaning of my problem, but when I try to set it to true I have a message 'Variable/field write-protected'.
    Do the variable $PLST_OVLD mean something to anyone? Or if it's not related at all ?
    Edited once, last by Theo.g (July 6, 2021 at 12:58 PM).
  • Frank Yeh
    35
    • May 12, 2022 at 6:48 AM
    • #27
    Hi Theo,
    I have just joined the forum and wanting to do something similar. May I ask what kind of barcode scanner did you use and how is it connect to the HMI?
    Thank you.
  • Theo.g
    27
    • May 12, 2022 at 8:29 AM
    • #28
    Hello Frank Yeh,
    Welcome !
    I use a SYMBOL LI2208 barcode scanner, you can find it on amazon (https://www.amazon.com/Symbol-LI2208-…t/dp/B00EUN0M8I). And it's connected to my HMI by USB.
  • Frank Yeh
    35
    • May 16, 2022 at 6:09 AM
    • #29
    Theo.g thank you for the information sir. Is the scanner being called upon by a Karel program and processed to change register values?
  • hermann
    407
    2,613
    • May 16, 2022 at 7:19 AM
    • #30
    Quote from Theo.g
    .. I don't have a PLC, The HMI I'm using is a Proface SP5000 series communicating with the robot in ethernet/IP and using SNPX..
    Quote from Theo.g
    .. And it's connected to my HMI by USB.
  • Frank Yeh
    35
    • May 18, 2022 at 7:25 AM
    • #31
    hermann thank you sir! I am not as familiar with the HMI side of things. I will look into it.
  • bg logic
  • Call
  • CR-7iA/L
  • IHM
  • R30-iB plus
  • String register
  • Barcode scanner
