Fanuc robot 120iC 10L don't weld
  • Vladarius
  • May 4, 2021 at 8:09 AM
  • Vladarius
    10
    94
    I have weird problem with my fanuc robot. Comunication betweed welding powersource is ok .. touch sensing works , gas button, wire buttons ok but when i wand weld robot makes like is welding off.. No error.. even if i make override lower no error appiers.. Welding io are ok.. triing from DO turn on welding process will start but not from arcstart command.. don't know why..
  • R47
    109
    • May 4, 2021 at 3:32 PM
    Hi Vladarius,
    did you configurated the weld interface?
  • Vladarius
    10
    94
    • May 5, 2021 at 10:59 AM
    Hello Yes.
    I give you pictures in attachment.
    Images
      • 438.57 kB
      • 1,920 × 1,080
      • 43
      • 391.18 kB
      • 1,920 × 1,080
      • 33
  • notverycreative
    • May 6, 2021 at 2:39 AM
    See if anything is interconnected to DO[9] in the interconnect menu.
    Sounds to me like there is a bit simulated off in the Weld I/O menu
  • Vladarius
    10
    94
    • May 6, 2021 at 3:10 PM
    Hello notverycreative,
    I checked interconnect menu and nothing to DO[9].
    Nothing simulated..
    Strange thing is that i sent to Fanuc service my backup all from above and they told me that simulation in robotguide turn DO9 on with arc start .. but my real robot not..
    They told me that they come to my robot and do complete reinstall..
  • neighbour1
    44
    405
    • May 6, 2021 at 4:34 PM
    It's really interesting case!
    Let us know when you figure out with them what's going on.
  • Vladarius
    10
    94
    • May 6, 2021 at 7:48 PM
    It is.. i think is something hidden is some variable.. I let here know..
  • R47
    109
    • May 7, 2021 at 7:39 AM
    ..but you are running in 100% right?
  • fmiroslav
    18
    91
    • May 7, 2021 at 10:00 AM
    Quote from Vladarius
    Similar problem with CRX-10iA, R30iB Mini Plus, Wire +, Wire -, Gas Purge, all working with dedicated DO, only Weld Start wouldn't. It was suggested to me to use WO1 but for that is necessary to have CRW11 card. I override this issue with additional command to DO[***] ON and OFF.
    CRW11 is connector and
    Process I/O board MB, A05B-2650-J061 is interface card with
    5 WI, 4 (sink) WO, 2 D/A
    Edited once, last by fmiroslav (May 7, 2021 at 10:19 AM).
  • neighbour1
    44
    405
    • May 7, 2021 at 10:06 AM
    Quote from fmiroslav
    Well... if I remember properly, there were some system variables to configure WO as a standard DO... haveing a bit o time, when I find it I'll post.
  • fmiroslav
    18
    91
    • May 7, 2021 at 3:13 PM
    • #11
    Arc starting and Weld start but no one in reality activate DO[101]
    CALL -INST_EASYAW_START() doesn't change DO status
  • neighbour1
    44
    405
    • May 7, 2021 at 5:36 PM
    • #12
    I ment I/Os like in the I/O Weld Out screen were WOs not DOs like you have, but using some variables it was changed in the system to DOs, even in the screen it were visible like WOs.
  • fmiroslav
    18
    91
    • May 10, 2021 at 8:40 AM
    • #13
    Quote from neighbour1
    Without proper hardware error was occurred.
    Images
      • 203.4 kB
      • 1,600 × 1,200
      • 16
  • Vladarius
    10
    94
    • May 11, 2021 at 7:17 AM
    • #14
    Quote from R47
    yes offcoarse.. but when you have welding off you can go with lower override but when you have welding on you must have 100.. but our robot behave like you have weld off.. no error when you have for example 85 percent just goes slower but no error because override..
  • R47
    109
    • May 11, 2021 at 8:01 AM
    • #15
    i assume the function Weld from Teach Pendant is also on.
  • R47
    109
    • May 11, 2021 at 8:02 AM
    • #16
    Menu--> SETUP --> Weld System
  • Vladarius
    10
    94
    • May 11, 2021 at 12:12 PM
    • #17
    Quote from R47
    Yes..
  • wind1119
    • May 12, 2021 at 3:19 PM
    • #18
    SET SYSTEM Variables $AWEPRR[1].$VENDOR_ID=108,Try it!
  • notverycreative
    • May 12, 2021 at 4:37 PM
    • #19
    Vladarius, you may have already checked, but another thing to check is to make sure the robot is not in "Tryout Mode"
    Menu --> i/o --> Cell Interface --> Press f3 to toggle between in/out
  • Vladarius
    10
    94
    • May 13, 2021 at 12:59 PM
    • #20
    Tryout Mode is off
Similar Threads
  • Stopping Robot @ the start of a weld.
    • Nddwind
    • July 21, 2019 at 5:50 PM
    • Fanuc Robot Forum
  • Equipment and group settings
    • Ericv
    • February 7, 2020 at 2:52 PM
    • Fanuc Robot Forum
  • Challenger ArcMate question
    • guilherme.simoes
    • December 6, 2017 at 12:57 PM
    • Fanuc Robot Forum
  • Weld Enable won't work on auto
    • RichElsley
    • August 12, 2019 at 9:10 AM
    • Fanuc Robot Forum
  • TAST troubleshooting
    • swilliams13
    • March 12, 2019 at 9:48 PM
    • Fanuc Robot Forum
  • Weld Parameters
    • Zuluzahn
    • June 11, 2018 at 2:40 PM
    • Fanuc Robot Forum
  • OS-147 Assert MAIN %d %d %s
    • Robo_Eng_13
    • March 5, 2018 at 3:16 PM
    • Fanuc Robot Forum
  • Limit set missing on fanuc arc mate 120ic
    • T4HS
    • March 13, 2018 at 2:20 PM
    • Fanuc Robot Forum
  • Error fronius welding equipment and arc mate 120ic
    • xaryd
    • November 13, 2017 at 11:28 AM
    • Fanuc Robot Forum
  • [SOLVED] Random failure in arc welding
    • matt_dct
    • May 4, 2017 at 8:13 PM
    • Fanuc Robot Forum
