Just want to check my understanding of position registers (PR). So I am thinking of PRs as a sort of global position variable that is not specific to any single TP program. So I can use a PR in one or more TP programs, unlike a standard position that is local to the TP program it was created in.
Hope that is correct so far.
The part I am less sure of is in regard to how a PR is used within a custom user frame (UF). So let's say that I just created UF(3) and I then set the active frame to UF(3) and then I create a few new PRs. Will the PRs be tied to the UF(3) or are PRs always tied to the default world coordinate system? Typically when you teach a basic point you need to pay attention to the active user frame, is this also true for PRs?
Thanks very much
