We have KRC4 robot KSS 8.5.6.
I was wondering if the calls of the submit interpreter are somehow related to the robot program.
I know SPS is cyclically called, but can the robot program at any line of its code be interrupted, or are there restrictions where a call of the sps is not possible. I should like to know that for the synchronisation between robot program and sps program.
Calls of SPS
Plc_User -
April 29, 2021 at 7:42 AM -
Sps is not cyclically called, it's called once and then runs. There is (usually) a loop inside, that runs cyclically.
Don't understand what you mean by this.
Robot program can be interrupted at (and may be inbetween) any line of the program.
That sometimes makes synchronisation a bit fiddly.
Level 0 Interpreter (SPS) and Level 1 Interpreter (Robot) are completely asynchronous. Their only real interaction is that they can both access the same pool of I/O and global variables.
What are you trying to accomplish? "Interrupt" has a specific meaning, but your description sounds like you want something else.
check RESUME command
