External Axis E1 : Unmaster / Remaster via KRL
  • SU05LLY
  • April 23, 2021 at 6:37 PM
  • SU05LLY
    30
    Good afternoon Forum,
    What do they say...NEVER make changes on a Friday.....What have I been asked to do an hour before "GoHome time" = #Grrr.
    Tech specs:
    KR3 - R540
    KRC4 Compact
    KSS 8.6.6
    Additional axis
    Query:
    Rotary table ( E1 ) to act like a chuck in a lathe - continous motion while robot linearly moves up a valve stem. Exact rotation vrs linear displacement is W.I.P.
    WoV:
    I have this external axis set up as : ENDLESS.
    .SRC:
    I set the .E1 as : ASYNC
    I then use : ASYPTP {E1 20000.0}#AS_PROG
    Then LIN move the axis from point A to point B.......The number of rotations of .E1 is matched to the linear displacement.(Crude I know)
    Next linear move I go the opposite way :to decrement the stack up of degree's : ASYPTP {E1 -20000.0}#AS_PROG
    Then LIN move the axis from point B to point A
    Problem query:
    I sometimes have a delta between the physical and resolver 0 degree. Therefore making my displacement vrs rotations a load of tosh...
    Is there a way for me to Unmaster and then Remaster in KRL as this resets the overflow and therefore I can drive to .E1 0.0 PRE any measured LIN movements?.
    I note this isn't great, but sadly this process does not suite using a KUKA external axis to be a spindle like device...However, I'm having to work with what I have currently.
    any help / offerings GREATLY received..
    Have a good weekend community
  • panic mode
    1,267
    13,033
    • April 23, 2021 at 6:48 PM
    so you move E1 back and forth and axis position does not match where you started from?
    check for slip or backlash...
Similar Threads
  • Mastering homemade external axis with a KR150 KUKA motor
    • jschmidt
    • May 8, 2018 at 4:50 PM
    • KUKA Robot Forum
