Please help regarding OTC robot
How to take backup which I can see in computer notepad
I haven't touched a Nachi in ~15 years, but on the WX series controllers, "backups" were not ASCII files. One had to use a separate menu option, "Export to ASCII", or something like that, in order to generate human-readable text files.
Export Ascii option is available in pendant itself?
It was on the Nachi WXs I used, years ago.
Procedure to convert Robot program (Executable) to Robot Language (Source) as below
SERVICEàPROGRAM CONVERSIONàLANGUAGEàConversion Type(SourceßExe),Output Language(MOVEX-J) (If Conversion is to be in Joint Angles) àWORK Folder, Program Subfolderà Select Program Number which you need to Convert to ASCII file and Destination , EXECUTE.
Format for ASCII file (Source), readable in notepad is **Robot Mechanism -“A”-Prog.No **
