The DEVNET driver is missing from the [ DRIVERS ] section of IOSYS.INI.
Should be a line that looks like this:
DEVNET=2,dnInit,dndrv.o
as mentioned in post #12
Read my post. Not DN2DRV, DNDRV.
Okay Skyfire and MOM, I added the devnet driver to the iosys. But the error from the photo attached occurred. Is there something else missing? Is the supply of the card okay? I already performed a coldstart and reconfigured the IOs
I deleted the number 2 on DN2DRV, and saved, but the same message appeared. I reconfigured the IO’s and performed a cold start on the controller. Same message. What else can be missing? Should I take the iosys.ini from a new KRC2? Like I did with the devnet.ini archive.
Like every other fieldbus, shield must be connected to ground in ONE place.
Unlike other fieldbusses, DeviceNet requires user to supply 24VDC to the bus.
as SkyFire suggested:
your latetest picture shows
DEVNET=2,dnInit,dn2drv.o
you also can comment the MFC out (because not used):
;MFC=0,mfcEntry,mfcdrv.o
I supplied the red and black wire with 24V, now the LEDs are like on the photo:
Yes, I deleted the number 2 and still had the same error.
I already tried to do this, but it looks like it didn't changed anything.
I'm starting to despair haha
What error messages do you have rigth now?
the second left led shows that (CAN)bus is running
the first right led shows: you have Us
the second right led shows: Up is missing (this is the reason you won't see any outputs)
the third right led shows: K-Bus is running
These are the errors:
actually on the left side of the BK you will find the meaning of the differern led's
your wiring still looks kond of weird:
Normally the 24 Volts
on the can bus connector
for Us
for Up
should come from differnent power sources
One reason: if you have a short in Up then the complete system goes down
no wonder it was not used
to your post #32
can you show the content of the drivers directory?
What kss version do you have?
QuoteOne reason: if you have a short in Up then the complete system goes down
if you have a short without circuit branch protection.
QuoteI'm starting to despair haha
not true... if that was the case you would know ins and outs of how to wire it, what the LEDs mean etc.
No, don't copy iosys.ini from KRC2 to KRC1!
The DeviceNet driver has been changed since KSS V5.0 Build3, as already told.
Be shure that on drive C: the file dndrv.o exist in subdirectory \driver
and tell us the KSS Version like 2.2.8, 2.3.24, 3.2, 4.1. What version do you have?
Sorry, you already posted it in post #1 (ages ago): KSS V2.3.34 SP08
The dn2drv.o can be used starting with V 4.1 (I believe) and therefore your configuration of i/o's in iosys.ini is incorrect
please provide us with the information asked for
This is the content of the drivers directory. It really does not have dndrv.o. What should I do to get the devnet driver now?
the driver should be on the cd or on drive d.:
Hello guys.
I did not found that driver dndrv.o on the HD, as well as the devnet.ini archive was missing, what I believe is actually weird (I had to take a copy from our KRC2, one of you guys told me that the devnet.ini is same for KRC1 and KRC2). I tried the same thing with the driver dndrv.0, made a copy from our KRC2, tried to configure like "DEVNET=2,dnInit,dndrv.o (by renaming it), DEVNET=2,dnInit,dn2drv.o, DEVNET=2,dnInit,Dndrv.o and DEVNET=2,dnInit,Dn2drv.o. Still have the same error, I does not recognizes the driver from the KRC2.
I believed it was worth to try. There is no way you can post the original archive here right? Cause it is from KUKA and stuff.
Display MoreWhat error messages do you have rigth now?
Im really sorry for my ignorance, but what does it means to "Have Us" and "Up is missing" what are these?
do you have the cd?
What do you mean by KRC2 (what kss version?)?
No, I don't have the CD.
By KRC2 I mean the we have a KUKA KRC2 here KSS 5.6.9. I made a copy of the devnet.ini arquive of the HD from that KRC2, I'm using on the KRC1 that I'm trying to configure the devicenet. That file was also missing.
