Hi everyone
My XP5/XM5 connector just broken during transport.
Is there any replacement option on the connector? Or I need to replace the whole motor
A4 and A5 axis work fine, no problem
Hi everyone
The simple solution is to use some special aluminum welding/brazing rods
that is a aluminum-zinc alloy(melts about 400 °C) and solders aluminum alloys very good and it is much harder than aluminum(because of zinc content).
The only tools you need is a propane gas(mapp gas) & an stainless steel wire brush.
Guarantee result..
https://www.instructables.com/How-to-weld-aluminum/
Before apply any heat you must remove the connector with plastics/cables etc
