SWITCH command
  • Hello all
    KSS V4.1.5
    In a position robot waits for three different inputs: $IN [2] OR $IN[6] OR $IN[7]
    I defined three inputs like this:
    SIGNAL choiise $IN[2] to $IN[7]
    So after the WAIT command, I wrote this:
    SWITCH choiise
    Case 1
    Case 2
    Case 3
    DEFAULT
    ENDSWITCH
    My problem:
    SWITCH just works for Case 1 related to $IN[2] and for other cases program jumps to the DEFAULT. I think the problem backs to the number of the cases. maybe I must change the number 2 and 3 .
    thanks for any help
    Edited 2 times, last by Robotmei ().
  • those inputs need to be together.. no gap... then it makes sense to create and evaluate mentioned signal.
    now you have signal encompass also inputs 3,4,5 which should not be there. this means you need to consider possible non-zero values at those inputs which complicates things.
    i would suggest two swap inputs 2 and 5, or 2 and 8 so that inputs making up signal are grouped.
    alternatively
