Can IMSTP, SFSPD, and Enable be tied together?
  • TitusLepic
  • April 8, 2021 at 4:41 PM
  • TitusLepic
    112
    442
    I'm installing a used robot and planning on controlling it from a hardwired PLC. Since the IMSTP, SFSPD, and Enable signals all turn on and off together; is it bad practice to use a single PLC output to control all three and jumper them together at the robot input card?
  • Go to Best Answer
  • HawkME
    568
    10
    3,268
    • April 8, 2021 at 6:14 PM
    That's how I would do it. In my mind it is separate from your safety signals so doesn't really matter.
  • neighbour1
    44
    405
    • April 8, 2021 at 6:16 PM
    • Best Answer
    Sometimes I do it, it works without any problems. But mind that there are differences in robot's behaviour according to those signals. If it's not a problem for you, feel free.
    Do you have a modular (physical ) I/O? Configure it as the same signal (rack ,slot, start = the same for all of them) and then you save two more ins for other purpose. Sometime I also do it even with Profibus, Profinet, DvNet, etc., because I'm lazy :winking_face:
    When needed I also "cross" 4 signals: IMSTP, Hold, SFSPD, Enable - they also could work together.
Similar Threads
  • UI/UO Functionality
    • the_indiRoboter
    • August 29, 2020 at 4:00 AM
    • Fanuc Robot Forum
  • How to Map DIO to UOP on R-30iA?
    • alive15
    • January 10, 2018 at 2:52 PM
    • Fanuc Robot Forum
  • Help
    • K
    • May 8, 2018 at 2:59 PM
    • Fanuc Robot Forum
