KRC4 Conveyor Tracking Read Current Part Travel Distance
  • Hi Everyone,
    Brief Resume:
    I need to check the current distance of the part to the sensor that triggers the conveyor synchronization. According to the manual I have a function to read the current conveyor speed but not the current distance.
    The code I am using is posted bellow the message.
    System:
    WorkVisual 5.0
    KRC4
    KSS 8.5.8
    Conveyor 7.1.2
    Manual I am reading: ConveyorTech 7.1 and Kuka System Variables
    Context:
    In the conveyor follow and conveyor skip instructions I have a Wait Distance parameter. After the wait distance is reached the program moves to de conv move instruction where I have my part program.
    After browsing the follow and skip instructions I found that this distance is controlled using the $SEN_PREA_C[1] variable. According to the manual: "Exchange of real values in main run between the controller and the sensor interface program", which sounds about what I need.
    Now, when I try to control this variable in my part program I get these values:
    REAL PartDistances[4]
    PartDistances[1]=0.0
    PartDistances[2]=0.0
    PartDistances[3]=1414.10522
    PartDistances[4]=1738.78918
    1- At the beggining of the program after the trigger (at 1230mm)
    2- After running the Home Position (Base 0) and Waiting a Timer
    3- In the middle of the program (Value Looks Ok)
    4- At the end of the program (Value Looks Ok)
    As you can see the first 2 values come out as 0.0 and I kinda need to know where the part is at these times. Is there a way to get the current distance or the variable $SEN_PREA_C only starts working after the first schyncronized movement?
    Thanks For Your Help
    CODE:
    DEF Main_Del( )
    INI
    CONV INI
    ;Start the Conveyor
    Conveyor.INI_OFF LinearConveyor1
    Conveyor.ON LinearConveyor1
    ;Follow first Part
    Conveyor.FOLLOW LinearConveyor1, Movement 1, Cancel on: Max_time 240, Input 1, Input-Level TRUE, Flag 1, Flag-Level TRUE, WaitDist 1230, MaxDist 3000
    LOOP
    Conveyor.Skip LinearConveyor1, Skip to part index 1, Movement 1, Cancel on: Max_time 240, Input 1, Input-Level TRUE, Flag 1, Flag-Level TRUE, WaitDist 1250, MaxDist 3000
    Conveyor.Quit LinearConveyor1, Stop after error FALSE, Reset SEN_PREA_C TRUE
    ENDLOOP
    END
    DEF CONV_MOV(Z_CONV_NBR:IN,Z_MOV_NBR:IN)
    INI CONV_MOV
    CONVEYOR 1 MOVEMENT GROUP 1
    Part_Del()
    CONVEYOR 1 MOVEMENT GROUP 2
    CONVEYOR 2 MOVEMENT GROUP 1
    CONVEYOR 2 MOVEMENT GROUP 2
    CONVEYOR 3 MOVEMENT GROUP 1
    CONVEYOR 3 MOVEMENT GROUP 2
    CONVEYOR 4 MOVEMENT GROUP 1
    CONVEYOR 4 MOVEMENT GROUP 2
    CONVEYOR 5 MOVEMENT GROUP 1
    CONVEYOR 5 MOVEMENT GROUP 2
    END CONV_MOV
      CONTINUE
      END
    DEF Part_Del( )
    INI
    ;Read Distance
    PartDistances[1]= $SEN_PREA_C[Z_SEN_PREA_NBR[1]]
    PTP HOME1 VEL=100 % DEFAULT
    WAIT TIME=2.1 SEC
    ;Read Distance
    PartDistances[2]= $SEN_PREA_C[Z_SEN_PREA_NBR[1]]
    ;P4
    $BWDSTART = FALSE
    LDAT_ACT = LCPDAT4
    FDAT_ACT = FP4
    BAS(#CP_PARAMS, 0.25)
    SET_CD_PARAMS (0)
    LIN {X 0.0, Y 0.0, Z -170.0, A 0.0, B 0.0, C 0.0}:XP4 C_Dis C_Dis
    ;P3
    $BWDSTART = FALSE
    LDAT_ACT = LCPDAT3
    FDAT_ACT = FP3
    BAS(#CP_PARAMS, 2.0)
    SET_CD_PARAMS (0)
    LIN {X 0.0, Y 0.0, Z -70.0, A 0.0, B 0.0, C 0.0}:XP3 C_Dis C_Dis
    ;Read Distance
    PartDistances[3]= $SEN_PREA_C[Z_SEN_PREA_NBR[1]]
    ;P2
    $BWDSTART = FALSE
    LDAT_ACT = LCPDAT2
    FDAT_ACT = FP2
    SET_CD_PARAMS (0)
    LIN {X 0.0, Y 0.0, Z -170.0, A 0.0, B 0.0, C 0.0}:XP2 C_Dis C_Dis
    ;P1
    $BWDSTART = FALSE
    LDAT_ACT = LCPDAT1
    FDAT_ACT = FP1
    SET_CD_PARAMS (0)
    LIN {X 0.0, Y 0.0, Z -20.0, A 0.0, B 0.0, C 0.0}:XP1 C_Dis C_Dis
    ;Read Distance
    PartDistances[4]= $SEN_PREA_C[Z_SEN_PREA_NBR[1]]
    END
