2D array data in Karel
  • zhaoxiang chen
  • April 7, 2021 at 9:56 PM
  • zhaoxiang chen
    43
    Hi guys,
    currently, I am looking for a proper way to define and use 2D array in KAREL program.
    the general concept is that,
    array[i,j]:
    10
    11 5
    7 13 14,
    and 13 will be read and use when i=3 and j=2,
    is there anyone happen to know how to program this?
    best regards,
    Chen
  • Go to Best Answer
  • jmd2777
    34
    193
    • April 7, 2021 at 10:50 PM
    To declare the array:
    two_d_array: ARRAY[3,3] OF INTEGER--2D Array
    To access elements in the array:
    two_d_array[3,2]=13
  • zhaoxiang chen
    43
    • April 8, 2021 at 3:05 PM
    Quote from jmd2777
    two_d_array[3,2]=13
    hi jmd2777,
    thank you for your reply.
    once the 2D array is created by Karel, is it possible to read the values with for-loops in TP program?
    for instance, using two registers represent i and j in for-loops in TP program, and in each loop a specific value corresponding to the index can be read from the array.
    regards,
    Chen
  • jmd2777
    34
    193
    • April 8, 2021 at 3:27 PM
    Chen,
    I don't know how to access a Karel variable in a TP program. One alternative is to have the Karel program read the registers storing i and j. Then the Karel program could copy the value from the 2D array into a register.
    So in your TP program you would set i and j register value. Then call the Karel program, or if the Karel program is always running you could turn on a FLAG that indicates you want to get a new value and the Karel program would see the FLAG and retrieve the value from the 2D array and store it in a register.
  • zhaoxiang chen
    43
    • April 8, 2021 at 3:57 PM
    Quote from jmd2777
    Chen,
    JM,
    i agree with your strategy, but still have one concern that:
    once the 2D array[i,j] is created in KAREL program, is it saved permanently ? or it is only existing when karel program is running?
  • pdl
    266
    1,506
    • April 8, 2021 at 4:19 PM
    Use the translator directive %CMOSVARS
    If %CMOSVARS is specified in the program, then all static variables by default will be created in permanent memory.
    If %CMOSVARS is not specified, then all static variables by default will be created in temporary memory.
  • jmd2777
    34
    193
    • April 8, 2021 at 4:25 PM
    • Best Answer
    Chen,
    The variable is permanent. You may have noticed that after deleting a KAREL program named kar_prog from the robot, there is still a file named kar_prog.vr. That .vr file stores the KAREL variables. If you delete the .vr file, then the KAREL variable values will be lost.
    2 things that may help:
    1. The KAREL command GET_VAR can access variables from other KAREL programs. For example, you could have 2 KAREL programs: A) create_2d_array and B) get_2d_array_value. You could call get_2d_array_value from your TP program. It would use GET_VAR to access the 2D array in create_2d and then copy the value to a register.
    2. There is a convenient way to check the value of your KAREL variables from the Teach Pendant. Go to Select screen, select a KAREL program and press Enter key. Press Data button->Type->KAREL Vars. You will be able to see the KAREL variables for the currently selected program.
  • zhaoxiang chen
    43
    • April 8, 2021 at 4:31 PM
    Quote from jmd2777
    Chen,
    thank you for your help, that is really helpful.
  • zhaoxiang chen
    43
    • April 8, 2021 at 4:38 PM
    Quote from pdl
    hi pdl,
    thanks for your reply,
    for creating a .DT file in Karel, i make file path as MC: xxx.dt, it works well in roboguide, but have not tried in real controller, do you have any experience or suggestion about choosing the memory device?
    regards,
    Chen
  • pdl
    266
    1,506
    • April 8, 2021 at 11:06 PM
    What is the data you're collecting and what is it used for? How often will this data change?
  • zhaoxiang chen
    43
    • April 9, 2021 at 10:26 AM
    • #11
    Quote from pdl
    pdl,
    i am trying to collect calculation result in KAREL program, so that the file can be export with USB. and the calculation is one time job only, not a realtime job which need to write and read hundred of thousands times.
    regards,
    Chen
  • zhaoxiang chen
    43
    • April 9, 2021 at 10:35 AM
    • #12
    Quote from pdl
    i used %CMOSVARS in program, but once i restart roboguide, the calculated variables are removed. the data karel variables are reset. do you know what is the reason for that?
Similar Threads
  • What is the best way to store data
    • RookieWithRobots
    • October 14, 2019 at 1:53 PM
    • Fanuc Robot Forum
  • system variables for userframe position
    • zhaoxiang chen
    • July 22, 2020 at 4:35 PM
    • Fanuc Robot Forum
  • Karel server for constant input data updating
    • dcrb
    • March 8, 2021 at 4:16 PM
    • Fanuc Robot Forum
  • Custom Log File
    • Kahless01
    • September 17, 2020 at 6:34 PM
    • Fanuc Robot Forum
  • Load position registers and registers from KAREL dataset
    • RoboDrillx
    • January 2, 2020 at 10:32 PM
    • Fanuc Robot Forum
  • Karel array of string
    • PP1727
    • January 2, 2020 at 1:04 PM
    • Fanuc Robot Forum
  • Best way to handle big array
    • RookieWithRobots
    • March 25, 2019 at 5:11 PM
    • Fanuc Robot Forum
  • KAREL INTP-311 (Uninitialized data) while using var_1 FROM prog: ARRAY
    • odojak1715
    • March 29, 2019 at 8:45 AM
    • Fanuc Robot Forum
  • KAREL: Getting a list of all files in folder
    • maSu
    • February 16, 2018 at 3:41 PM
    • Fanuc Robot Forum
