I'm working on a YRC1000 controller, and have set the S2C701 parameter to 1 to allow me override speed using input signals. I configured the S4C287 parameter to the correct input group and set the S4C2888 parameter to 50, and was able to successfully override the speed from 100% down to 50% when the signal went high (at the bottom of the playback screen, I have the message saying "Speed Adjustment" and "Ratio: 50%").
When I turn off the signal, the message at the bottom of the screen disappears, but the robot speed doesn't revert back to 100%, instead staying at 50% until I switch it back to Teach Mode.
How do I make sure the robot returns to its original speed once the signal is turned off without having to switch it to Teach Mode?
