I have an old rj2 with a s420iw. Whenever I try to make a backup using kfloppy I get that memory error after the first file and the system freezes. It backs up all the program files fine but has this issue when I do a controller backup. When I restart the system everything seems to go back to normal. Anyone have any suggestions how to fix this? I don't have any backups for the controller os.
rj2 memory error d24-d31
Voids Warranties -
April 5, 2021 at 4:19 AM -
You can do an All of Above from the warm start file menu?
Your issue is trying to do a Controller backup from the CTRL Start 2 menu?
Not 100% on this but I seem to remember needing the controller backup option. Check Status menu > Config and see if option is there.
I've done an all of above backup from the first CTRL menu. Yes, the problem is when I do a controller backup from CTRL 2. It writes the first file then crashes when doing the second. I checked and it appears the controller backup option is installed. It shows up under Status -> Version ID.
I vaguely remember having this problem a very long time ago and it was something silly like the local/remote switch, sometimes bad Kfloppy cable, ...
Try toggling the large buffers in Kfloppy. Make sure logging is off.
Can you post a pic of the memory error?
Register dumps are not good. Don't know if BACKUP02 is the FROM or CMOS.
Try deleting any programs and data not used. Change directory to FR and see if there are any copies located there that can be deleted.
There is risk and hate to mess with something working, but you could load in your backup and see if it overwrites the problem. Make sure you record your master counts and all frame data just in case.
