Howdy all,
We recently purchased a used KR 1000 TItan F with a KRC2 from a resale vendor. It is now installed in our warehouse, and there is fluid leaking from the A3 joint, coming from the seam on which the axis rotates (NOT from the mounting seam of the servo motor). An image of the leak location is attached. (Note: the robot has dark metal slag deposits due to prior work in a cutoff operation - these are NOT the leak). The leaking fluid is blue-green, with little smell, causing me to believe that it is gear box oil.
The leak was not present at the time of purchase - I suspect this is because the robot was in storage configuration when we bought it, and we exercised it after it was properly mounted.
I have read the following thread:
It talks about an oil leak: the oil color matches ours, and user "the leg" mentions that it could be the seals on the gear box. How can I determine if the gear box seals are causing the issue?
