How do you program Fanuc robots?
  • How do you usually program Fanuc robots? 36
    The result is only visible to the participants.
    Hi guys,
    I'm about to start my new internal project. It's related to Roboguide and Fanuc programming. If you don't mind, could you participate in the following poll.
    Thank you in advance!
  • Notepad++, then Roboguide, then real robot.
    Notepad++ (or any other text editor) is used to start the project and do the heavy lifting. Scratch, copy, paste, etc. I know Roboguide has an internal (and somewhat hidden) text editor, but I prefer N++ because it is faster.
    With the raw program(s) written, is time to upload it to Roboguide and debug. Maybe teach some basic positions, etc.
    With these more "mature" programs, is time to upload in the robot itself, touch up the rest of the path and make tests.
    But this happens mostly on small projects with single/few robots. Big deployments normally have virtually commissioned OLP programs that in theory are plug and play.
    Emphasis on "In theory"...
  • The best way to start programming with a text editor is to copy some .LS files from an existing robot. .LS files are the text versions of the programs. Then you can see how it is constructed and practice making changes.
    Then you need a way to compile/convert the .LS files to .TP files. This can be done with Roboguide, OLPCPro, MakeTp, or Ascii upload.
  • I tried a few times to write my own LS files, but got frustrated with programs not importing, and offering no debug info.
    I now usually:
    1. create a cell in roboguide with all machine models to verify reachability
    2. create a roboguide 'simulation' program that quickly does the 'pick' and 'place' routines. No fancy logic... just checking paths are clear and cycle times, reducer life-expectancy, and overheating.
    3. draft my programs with pseudo-code in a text editor (Visual Studio Code). this allows me to make bird's-eye representation of my logic flow
    4. rewrite the programs on the virtual TP in roboguide
    5. teach all points in roboguide
    6. transfer programs and PRs or Ps to the physical robot
    7. touch up points
    If a program fails to import, there is usually an explanation in the alarm history, along with a line number. Some stuff, particularity involving UFRAME names usually, just craps out and don't give a line number.
    Check out the Fanuc position converter I wrote here!
  • If a program fails to import, there is usually an explanation in the alarm history, along with a line number. Some stuff, particularity involving UFRAME names usually, just craps out and don't give a line number.
    Yeah... I would export an LS file, perform no modifications, and it would fail when re-importing. I can't explain it.
  • When using N++ what language coding do you use in order to get the best TP code visibility?
    And second issue: which encoding do you use?
    I use my own syntax highlighting set. With N++ is pretty easy create a new one.
    Some years ago I uploaded my .xml file here on the forum.
    Re: Off line editor
    The current one is different. Simpler, I think. Follows attached.
    Regarding the syntax highlight, my biggest concerns are: what is a instruction, what is a comment, and, in FANUC case, what is a commented instruction.
    And, about encoding, N++ can handle this very well.
    But if You are creating a program from scratch, what You must observer isn't encoding, but line endings. Newer robots normally handle this well, but older robots wants UNIX (LF) line endings.
    Files
    • FANUC_TP.zip
      (990 Byte, downloaded 11 times, last: )
  • Currently I use similar extension for LS and KL in N++. But it doesn't make me feel better comparing with Roboguide option. Both versions is time consuming from all perspectives.
