Hi Everyone...
Can somebody help me by providing Data Transmission manual. It's an NX 100 controller. I have 1 serial port and 1 ethernet port, i can use either.
Thanks..
Hi Everyone...
Thanks..
If anyone have data transmissiobn function manual for NX100 controller please send. I am trying to connect insight vision camera with the controller through either ethernet or serial port. I have got error 4105" Wrong execution of save instruction [90]
Urgently we require the information. pls help.
Here you go,
if you need help or something just ask.
Thanks. I will check this and reply.
I am trying to connect a vision system with the motoman HP3 robot with NX 100 controller. I am not using any software recommended by motoman to do this
I am using a Insight 5000 series camera. I am trying to connect the robot & camera through RS232/ethernet. Has anyone tried out this. If so, please share the necessary details.
Also If anyone has manual for communicating vision system with robot controller
Rgds, Alagesan S
Here is the link to some manuals I have posted earlier.
At the moment i am working with a camera that is linked to the computer and then the pc is communicating by ethernet with the robot.
You should take you're time and search the forum i believe a lot questions are all ready answered.
Here is also a link to the vision/robotic part of the forum
greetings
Dragonfly
greetings
Dragonfly
hello Dragonfly
could you help me with Ethernet communication between PC and DX100?
my email :leafstar1989@163.com
best regards
I am trying to communicate with DX100 via LAN as mentioned in the High Speed Ethernet Server Function Manual.
I am trying to get the position data with the Robot Position Data Reading Command as per the Manual. The data sent is as follows (This in decimal form): [89, 69, 82, 67, 32, 0, 0, 0, 51, 49, 0, 0, 0, 0, 0, 0, 57, 57, 57, 57, 57, 57, 57, 57, 117, 0, 101, 0, 6, 14, 0, 0]
This is as per the packet format mentioned in the manual. The above data when converted to ASCII & hexadecimal reads as Y,E,R,C,0x20,0,0,0,'3','1',0,0,0,0,0,0,'9','9','9','9','9','9','9','9',0x75,0,101,0,6,0x0E,0,0.
I am getting a error in the reply which is Format Error (Access level error) as per the Manual. I am unable to find the error in the format. Please help.
