KUKA KRC4 TORQUE MONITORING
  • Gabigol
  • March 29, 2021 at 9:14 PM
  • Gabigol
    34
    Hello guys,
    I wanted to know how do I enable torque monitoring on KUKA KRC4 (KR 16 L8 arc HW). I went to display, variable, single, writed $TORQMON, updated in real time, moved all axis but the value does not change.
    I also wanted to know if there is a varible or a way to mesure the temperature of the servomotors.
  • AMaC756
    8
    • March 30, 2021 at 5:20 AM
    Try finding $TORQMON_DEF in the file …STEU\Mada\$custom.dat. This is where it is defined.
    Regarding monitoring motor temp, you could try the variable $MOT_TEMP, be aware as the units are in Kelvin.
    You can find all of this in the system variable documentation.
    Edited once, last by AMaC756 (March 30, 2021 at 5:26 AM).
    ljuba
    33
    5
    281
    • March 30, 2021 at 7:40 AM
    try searching for those in system variable manual. All that is explained and you also have the examples.
  • spiral
    146
    • March 30, 2021 at 8:00 AM
    $TORQUE_AXIS_ACT
  • Sidnei Steuernagel
    10
    • March 30, 2021 at 2:43 PM
    and what is the variable for monitoring the torque in the KRC2?
  • panic mode
    1,262
    13,027
    • March 30, 2021 at 2:58 PM
    open manual... use CTRL+F to open search window... enter search term such as torque...
    10
    • March 30, 2021 at 5:11 PM
    Searching the krc2 manual, I didn't understand which one I could use to check the current torque. In KRC4 it really is $ TORQUE_AXIS_ACT.
  • panic mode
    1,262
    13,027
    • March 30, 2021 at 5:34 PM
    i would check $CURR_ACT. it gives you direct reading of motor current. axis torque is proportional to motor current.
    btw.
    Quote
    this does not apply...
    KRC2 and KRC4 are hardware. variable and monitoring of variables is something done in software. and when topic related to software, one should specify KSS version. and in case of KRC2, there are many possible KSS versions (4.x, 5.x, 7.x). mentioning model of robot am or controller type is not exactly helpful for this. same goes for KRC4 - it support range of KSS versions and they can have different variables.
    READ FIRST...
    btw, when one knows variable in one KSS, but not in another, good place to start search are so called migration documents.
    10
    • March 30, 2021 at 6:43 PM
    Yes, you're right. Thanks
Similar Threads
  • KUKA collision detect/torque monitoring
    • ParkerAT
    • January 8, 2020 at 7:16 PM
    • KUKA Robot Forum
  • Maximum axis acceleration
    • RoboticsMan
    • December 11, 2018 at 2:03 PM
    • General Discussion of Industrial Robots Only
  • Torque Monitoring
