Hello everyone,
I need to control an EGP-40-N-N-IOL, a gripper from SCHUNK with an IO Link master, the BNI ECT-527-005-Z040 from BALLUFF.
According to kuka support the master is compatible.
I plan to get the material but want to be sur it's possible before and i'm experimenting some problems.
The problem :
The .xml of the gripper is not accepted when i'm selecting it as EtherCAT ESI, the inside of the window is just grey...
When i'm choosing INTERBUS FDCML i got this this error : Error while editing device description files: Object reference not set to an instance object.
This ios where i found the .xml :
https://ioddfinder.io-link.com/productvariants/search/19376
Is the .xml bad ? or something?
Also, I saw in a thread (which I can not find any more) that it was necessary to add to the master the modules that it had to control ... right click, add but i can't, is it normal ?
Work Visual V5.0.10, i added the package sunrise 1.3.15.0
Sunrise 1.16
Many thanks in advance
