Please help in setting these upper limit/lower limit values for servo gun
Please guide how calculate upper limit and how to calculate lower limit values.
You said that someone else had already set this up for you in a different thread.
This is set when you attach the servo gun and set the initial parameters from the servo gun suppliers datasheet.
Sir I asked to verify each setting that's why I asked here
Please suggest something if know about this setting
Mechanical Parameters are used to set the physical distance the gun can move.
This is set by mantissa and exponent to set resolution for encoder bits/distance.
When this is set, you then limit the distance by setting upper/lower values for gun to operate during opening and closing.
Depending on your 'motion direction' setting, will depend on whether your upper/lower are positive/negative values.
These parameters will be explicit to the motor/gearbox/coupling/encoder of the servo gun they are fitted to, therefore the supplier would have these data sheets prepared and entered during the installation and commissioning of the gun.
