I need to compile a karel prog to R-J3iB controller.
Is it possible to do it with RG or at that time there was only OLPC to do it?
Thanks a lot for help.
RoboGuide should be good back to version 5.3, which would be an RJ3. KFLOPPY should also work if you can find an old enough version.
I have a problem with RG (software in robot 6.30) - I'm able to create a KL file, but can't compile it - there's no possibility to choose "Built" field.
What about the build button in the code editor tool bar?
Also "grey" -> not active
I've found the exact same thing with my 6.31 robot (and made a thread where some solutions were suggested but none of them fixed the problem for me, here); build buttons are grayed out in RG. I have no problems translating 6.40 karel programs for my other robot though.
Ha! So WinOLPC as I thought at the beginning was your sollution
Thanks a lot for helping hand!
BTW: do you know what happens when I compile my karel prog in RG cell using software 6.40 and then try to load it into the robot with 6.30? Have you also tried this?
I just tried compiling with 6.40 and loaded to 6.31, and surprisingly it worked fine.
Good to know, thanks a lot for help!
