KUKA Axle clearance measurement
  • legityme
  • March 15, 2021 at 11:47 AM
  • legityme
    85
    Hello guys!
    I want to measure the clearance on the KUKA KRC2 KR1000axes to find out which one is loose. How should I do?
  • panic mode
    1,280
    13,083
    • March 15, 2021 at 12:35 PM
    It is called backlash. Services that can be done by user are listed in the robot manual.others require specialized tools or training
  • legityme
    85
    • March 15, 2021 at 7:12 PM
    Hello Panic Mode, thank you very much for your response;
    Can you explain how to do a backlash on the KRC2 robot? There is a way to see it via software like on the KRC4 with “check mastering”?
    Check mastering is the same thing as the backlash?
    Or can you send me and exemple of a document that has that explanation?
    Edited once, last by legityme: More information about my doubt (March 15, 2021 at 7:53 PM).
  • panic mode
    1,280
    13,083
    • March 15, 2021 at 9:03 PM
    no.... mastering tells to robot where to start measuring axis position... normally this is done when no load is acting on the axis so that joints, gearbox etc. are not compressed.
    check mastering... is like mastering but it tells you how existing measurement compares with last mastering. optionally you can save change to overwrite the measurement with new result.
    backlash tells how much axis can move. in case of KUKA, this is measured when predetermined force or torque is applied. this way backlash measurement is larger as it includes both free backlash and change due to compression. ideally one wants this to be as small as possible.
    here is explanation on a CNC
    External Content youtu.be
  • legityme
    85
    • March 18, 2021 at 3:28 PM
    Hello Panicmode, I would like to know if you could possibly make a procedure explaining how I should do this on bigger and smaller robots. I could pay for you service.
  • panic mode
    1,280
    13,083
    • March 18, 2021 at 3:34 PM
    i could... but why not take KUKA training on Mechanical servicing?
  • legityme
    85
    • March 18, 2021 at 6:55 PM
    No time to wait and no schedule, so what do you say?
