Has anyone had any luck sending a real number to a Fanuc Robot? If so, can you explain how? Thanks in advance.
Real Number to Fanuc Robot
BSykes -
March 12, 2021 at 4:54 PM -
You can use the HMI option (SNPX) to send/receive real numbers to/from an HMI to the robot registers. You can do the same for position registers with this same option. Search this forum and you will find several threads.
If you are using Ethernet/IP, you can use explicit messaging to do it.
I am using ENET. Please explain how to use explicit messaging.
ENET isn't a thing on Fanuc robots. EthernetIP is a thing.
Are you actually using the EthernetIP protocol with a PLC? Have you purchased the EthernetIP adapter or scanner option and installed it on the robot? If so please list what model of PLC you are using and what model of robot controller.
