Hello guys, I need help and a little bit of your knowledge, can you help me?
Well, Is there any other software that compiles Rapid code or just robotstudio?
Software to compile a rapid code.
- kennedyrsb
- Thread is Unresolved
It is not compiled at all, it is merely ascii text, so you can use any text editor.
Hi. Thank you for your answer...
I will explain my problem better. I'm trying to pass a code to the robot but it doesn't run.
what software can i use to find out where this code error is?
__________________________________________________________________________________________________
VERSION:1
LANGUAGE:ENGLISH
%%%MODULE MESA(SYSMODULE)
PERS bool bSTART:=FALSE;
PERS bool Troca_fim:=TRUE;
PERS bool Set_Start:=FALSE;
PERS bool Aux_Start:=FALSE;
PERS bool Memoria_Mesa:=FALSE;
PERS bool Giro_Mesa:=FALSE;PROC main()
IF I_bSTART=1 AND Troca_fim=FALSE THEN
Giro_Mesa:=TRUE;
IF I_bSTART=1 AND Troca_fim=TRUE THEN
Memoria_Mesa:=TRUE;
IF Memoria_Mesa=TRUE AND Troca_fim=FALSE THEN
Aux_Start:=TRUE;b:
IF Memoria_Mesa=TRUE THEN
PulseDO \High,\PLength:=1.0, O_LED_START;
IF Aux_Start=TRUE THEN
GOTO c;
ELSE
GOTO b;
ENDIF
ENDIF
c:
GOTO a;
ENDIF
a:
IF Giro_Mesa=TRUE THEN
bSTART:=FALSE;
Set O_LED_STOP;
Set O_LED_START;
Reset O_CIL_trava;
WaitDI I_CIL_TRAVAav,0;
WaitDI I_CIL_TRAVArec,1;
Reset O_CIL_avanc;
WaitDI I_CIL_AVANCOav,0;
WaitDI I_CIL_GIROav,1;
Set O_CIL_avanc;
WaitDI I_CIL_AVANCOav,1;
Set O_CIL_trava;
WaitDI I_CIL_GIROrec,1;
WaitDI I_CIL_GIROav,0;
WaitDI I_CIL_TRAVAav,1;
Reset O_CIL_avanc;
Troca_fim:=TRUE;
bSTART:=TRUE;
Aux_Start:=FALSE;
Giro_Mesa:=FALSE;
Troca_fim:=TRUE;
Reset O_LED_STOP;
ENDIF
ENDIF
ENDIF
ENDIF
ENDPROC
ENDMODULE -
IF THEN requires an ENDIF before you start another IF THEN
The text based editor in RobotStudio will alert you of syntactical errors, and which line they appear
what's wrong with that? you load the program / module and it gives you errors or you can't even load it?
the initial declaration suggests an S4 controller. what model of controller do you have?
