Remote/Local setup
  • TitusLepic
  • March 8, 2021 at 6:23 PM
  • TitusLepic
    113
    7
    442
    On the system/config screen, there are 4 options under Remote/Local setup - Remote, Local, External I/O, and OP panel key. I understand remote and local, but can't find any information on how External I/O and OP panel key work. Can anybody either explain them or tell me what manual I should be looking in?
    Thanks.
  • Fabian Munoz
    134
    Articles
    1,517
    • March 8, 2021 at 9:17 PM
    Retired but still helping
  • pdl
    272
    1,549
    • March 8, 2021 at 11:02 PM
    What is the difference between Local and OP panel key?
  • Hazard
    15
    55
    • March 9, 2021 at 12:23 AM
    OP panel key sets it so that you can switch between remote and local just by switching the key on the panel. Most of my robots are set this way.
  • pdl
    272
    1,549
    • March 9, 2021 at 12:30 AM
    AHHH! That makes sense, except that they haven't used an op panel key since the RJ3 days. I guess that's Fanuc for you.
  • CaioDiniz
    • November 16, 2021 at 1:53 PM
    Good Morning! How do i get my panel (R-2000ib) to start up in local setup mode ?
    Files
    pasted-from-clipboard.png 312 Byte – 654 Downloads
  • R47
    110
    • November 16, 2021 at 2:05 PM
    Hi CaioDiniz,
    its in "Menu"--> "Next"-->"System"-->"Config"
  • CaioDiniz
    • November 16, 2021 at 6:19 PM
    Hi R47,
    but when i restart the controller it goes back to remote status
  • pdl
    272
    1,549
    • November 16, 2021 at 8:32 PM
    Do you have any BG Logic running? Is there a cold or hot start autoexec program?
  • neighbour1
    44
    405
    • November 17, 2021 at 3:46 PM
    Create you own program (no motion) with the line $REMOTE_CFG.$REMOTE_TYPE = 2
    and then, do one of the two things:
    1. Run it in BG
    2. Run it in cold and hot start as R47 wrote.
  • CaioDiniz
    • January 14, 2022 at 2:30 PM
    • #11
    how do i run a routine in BG ?
  • neighbour1
    44
    405
    • January 14, 2022 at 6:55 PM
    • #12
    As I wrote above:
    1. Create the new program (no motion) eg. TEST with the line you need.
    2. MENU -> 6 SETUP -> BG Logic -> ENTER
    3. Choose you program TEST, then F2 RUN.
    That's all.
  • Lpoels
    5
    18
    • November 24, 2023 at 9:10 AM
    • #13
    Is there also a way to see how the robot is set? UOP Local or remote?
    So i can send that to the PLC
    -> Found it: SI2[remote] like Fabian Munoz viewd in the picture. Thank you!
    Edited once, last by Lpoels (November 24, 2023 at 10:47 AM).
Similar Threads
  • [Solved] Unable to start up program via PNS.
    • x3moonz
    • June 25, 2017 at 8:01 AM
    • Fanuc Robot Forum
  • Newbie can't turn on the automatic drive
    • Snteri112
    • October 28, 2020 at 2:29 PM
    • Fanuc Robot Forum
  • Auto Mode Run Issue --- LR Mate 200iD, R-30iB, Handling Tool Software
    • dfrazer21
    • October 12, 2017 at 8:07 PM
    • Fanuc Robot Forum
  • R-J3iB PNS Issues
    • tanky321
    • November 9, 2020 at 8:30 PM
    • Fanuc Robot Forum
  • Abort ALL
    • Errorcode
    • June 17, 2020 at 11:03 AM
    • Fanuc Robot Forum
  • run RJ2 by PLC
    • Robotmei
    • March 3, 2019 at 7:39 AM
    • Fanuc Robot Forum
  • Proface HMI controlling UOP signal
    • fatal546
    • July 25, 2018 at 9:51 AM
    • Fanuc Robot Forum
  • AUTO mode
    • Tanisamara
    • April 6, 2018 at 9:45 PM
    • Fanuc Robot Forum
  • Help
    • JMDukes77
    • October 23, 2017 at 8:40 PM
    • Fanuc Robot Forum
