Hello All,
We purchased a used robot cell with Fanuc R-30iA robots. The cell came with Allen Bradley 1738-AENT IO blocks installed but they will no communicate with the Robots over Ethernet IP.
It had been a few years since the modules were powered on so we had to re initialize a lot of settings to get the IO blocks status lights all to Green(chassis size, IP address etc) but now we are still unable to get the devices to "Running" state through the Ethernet IP section on the FANUC robot.
We can successfully ping our device and have tried a variety of different settings to no avail.
The rack consists of 10 "1738-IB8M12" Input modules, and 1 "1738-OB8EM23" output module.
We were convinced it was an issues with the IO modules because we couldn't get the "PointBus Status" light to stop blinking red, but then we adjusted out chassis size and that went away and we are now convinced it is an issue on the robot side, but have run out of ideas as how to remedy this.
Any info that could be shared on how to properly set your ethernet IP settings(Input assembly size, configuration instance etc) would be greatly appreciated, as right now we are basically going through other peoples examples and trying to copy them with no success.
Cheers,
