Need help on Controller Error message
  • Need help please.
    After inserting package to controller, an error message below appeared.
    Please let me know what could be the problem.
    Transfer failed.
    The local station configuration is not the same as the one on the controller.
    Either adjust the local station configuration and reinstall the station configuration, or load a project from the controller and accept the station configuration from the controller.
    More information on the differences can be found here.
    Topology Element 'KAKU_Sunrise_Cabinet_1': The selection of software elements is different. The following elements have been selected for one of the configurations only
    Ikarus AntiVirus Definition Files(.99244)
    Ikarus AntiVirus(v.2.7.30)
    Ikarus AntiVirus SmartHMI(v.1.8.0)
    Ikarus AntiVirus Service(v.1.15.0.5)
    com.kaku.service.virusScanner.ncf(v.1.15.05)
    Thank you in advance.
  • You got different project settings(Software options) on both sides.
    1. You may want to download the project from the controller first, and then work on it.
    2. You look for those software options that are not matching between the project of your controller and of your workbench, and select those on your workbench that are missing.
    - Under [StationSetup.cat] - [Software] tab
    3. If you are sure that your project of your workbench is the right one you need, you need to "Install" the project before trying "Synchronize".
    - Under [StationSetup.cat] - [Install] tab. Installation will delete whatever was in the controller, and install software options that you selected on your workbench. Installation is needed only once, now you can just Synchronize.
