Hello I have to put my robot back on when the bay has been moved for 1 year Is there a protocol to follow for its release under tention? a krc15 with a krc2 .
electrical refit protocol
Xav Pierrat -
March 4, 2021 at 10:19 AM -
tension?
sorry ,
Is there a protocol to follow for power supply?
No idea what you mean
KRC2s run on 3-phase, 400VAC. Your KRC2 may have a large transformer (usually mounted below the KRC2) with a ratio that depends on the local power grid. An American KRC2, for example, usually came with a 480:400 transformer, while some Canadian models came with a 575:400 transformer.
Assuming your transformer is correct for your power source, the protocol is simply to connect all three phases (plus earth ground) and turn on the KRC2. If the main ventilator fan runs backwards, you need to swap two of the three phase connections.
After 1 year with no power, the batteries are likely dead. So it will be important to keep the controller powered up for several hours on first power up, to charge the batteries. If the batteries are too old, they may not take a charge, so it may be necessary to replace them.
thanks
