When using $AUTOLOGIN3 is there a way through the plc to have it so you can login as different users with different levels? I’ve tried to figure it out but am stuck. We have badge access from the HMI and a edit lock button that goes to the controller which auto logs in install user. I’m wondering if you can have it log in different users also. To many cookies in the cookie jar and I’m trying to work with what we have, to make restrictions on editing. We use BGLOGIC for auto login I’m pretty sure.
Fanuc autologin3
- auto.junky
- Thread is Unresolved
Hi, iam not sure what you want. But yes, its possible to unlock a user true External signal.
You need to write it with karel.
I was thinking there was a way to have badge access from the HMI which logs into autologin3 to the pendant and whatever badge number you log into the HMI with, that would correlate you to let’s say John’s” badge. Then that would give “John’s” access level and restrictions. Instead of it always defaulting to install user level. Or if you could toggle an input on, which would correlate to John’s badge number and then that would set the user level for restrictions.
