KUKA KCP CONNECTION ERROR
  • Gabigol
  • March 2, 2021 at 7:52 PM
  • Gabigol
    34
    Hello guys, we have a KUKA KRC4 2013 with KSS 8.2.25, presenting 3 errors;
    -Speed of outer fan too low (Cause our external fan is dead, so that one is ok);
    -KCP connection error;
    -Safety stop;
    We already exchanged the smartpad and bipped the smartpad connection cable and power supply. Do you guys have any ideia of what it could be or what should we test? On KUKA Virtual Pendant, we press the deadman button and try to move the robot but it does not work
  • panic mode
    1,281
    13,091
    • March 2, 2021 at 8:13 PM
    dead fan is not ok but whatever...
    did you check if KPC boots? try connecting external monitor and then booting up. some older KPCs did not have video output so to check this one may also need a video card.
  • Gabigol
    34
    • March 2, 2021 at 8:19 PM
    Yes, the system starts normally, if I connect the monitor and disconnect the smartpad, the fault goes away.
    Edit: When I press the emergency button, or a deadman button, no different messages appears on the smartpad, what make sense, since the there is a connection error with the smartpad.
    Edited once, last by Gabigol (March 2, 2021 at 8:27 PM).
  • panic mode
    1,281
    13,091
    • March 2, 2021 at 8:28 PM
    if the same happens with different smartPads, that would suggest that problem is not on smartpad. most likely something may be wrong with the CCU or interface (wiring) between CCU and X19... perhaps bent or pushed out contacts if someone was trying to connect smartPad forcefully...
  • Gabigol
    34
    • March 5, 2021 at 8:52 PM
    Hello Panic Mode,
    The pins were ok, but two of them were inverted, I fixed it and the fault came out, but now the robot has the fan failure and safety stop.
    I can't get into start-up mode and when I go into security configuration, it looks like the touchup has been disabled, have you got something like that?
Similar Threads
  • Help! KUKA KRC4 SmartPAD unable to establish connection to KRC
    • tsui0620
    • May 1, 2018 at 12:46 PM
    • KUKA Robot Forum
  • KRC4 8.8.5 CIP safety
    • B302
    • February 16, 2021 at 5:36 AM
    • KUKA Robot Forum
  • Connection issue between Kuka Sim Pro 3 and OfficeLite 8.3
    • bneill93
    • May 23, 2018 at 4:20 PM
    • KUKA Robot Forum
  • RSI cannot set any outputs due to operator protections
    • Shopping Pallet
    • March 1, 2021 at 10:00 AM
    • KUKA Robot Forum
  • KRC 4 (2014). Version KSS 8.3.7. The robot Kuka KR 6-2. Kemppi 450 Pulse (DeviceNet)
    • NickBabin
    • February 3, 2021 at 1:49 PM
    • KUKA Robot Forum
  • Kuka KR 6-2 + Kemppi 450 Pulse
    • NickBabin
    • January 28, 2021 at 5:11 AM
    • General Discussion of Industrial Robots Only
    • NickBabin
    • January 27, 2021 at 1:37 PM
    • KUKA Robot Forum
  • Cannot connect to KRC4 controller with Work Visual
    • RobL1234
    • September 15, 2020 at 9:02 AM
    • KUKA Robot Forum
  • KUKA RSI_CREATE: Connect error FTD6_SEN
    • kokkes
    • October 8, 2019 at 11:49 AM
    • KUKA Robot Forum
  • Problem with connection KUKA KC4, WoV
    • stiepan19pl
    • August 6, 2019 at 8:13 AM
    • KUKA Robot Forum
  • SMARTPAD
