I am creating a DCS zone around my tool but have a problem. For whatever reason our engineer offset the plate that mounts to J6 by 22.5 degrees. So when i put J6 at 0 degrees the tool is actually at 22.5 degrees. I created a box around my tool but there is no option to offset about J6. When i look at the the DCS zone around my tool it by default wants to match where J6 is at. Any ideas how to correct this?
DCS User Model
- Kyle0588
- Thread is Unresolved
Teach a tool frame that is 22.5 degrees and use that tool frame in item 4
Basically you are mounting that cube on the frame and not on the flange
I already had that tool frame taught with 22.5 degrees. I linked my User model to my DCS Cartesian Check under Target Model. Now when i go back to my User Model and try to change item 4 to 1 (tool frame 1) it says "unregistered tool frame".
I tried going to my tool frame under DCS and tried entering 1 under Tool Select and it gave me the same message
what do you have here ?
Okay i figured it out. I needed to keep Tool select at 0 and then change the first No from 0 to 1. thanks for your help Fabian
