robot in linear motion at world coordinates it does not maintain alignment at the tip of the tool
  • Nicolas Romero
  • February 26, 2021 at 9:26 PM
  • Nicolas Romero
    33
    the wave generator on axis 2 breaks, the gear unit on axis 2 was replaced and the other gear units were disassembled.
    after the assembly is giving the problem that it does not follow the linear movement in the word coordinate.
    foi masterizado comforme o manual e continua com o problema.
    robo nao utiliza tcp.
    does anyone already experience this problem?
  • HawkME
    568
    10
    3,268
    • February 26, 2021 at 10:15 PM
    Not sure exactly what you are saying.. sounds like you need to zero axis master.
  • Nicolas Romero
    33
    • February 26, 2021 at 11:07 PM
    A broken gearbox was replaced with a new gearbox.
    after that the axis 6 in the word coordinate does not follow a linear movement, that is, it does not start to rotate.
    it should be straight without moving.
  • HawkME
    568
    10
    3,268
    • February 26, 2021 at 11:49 PM
    Remaster
  • Nicolas Romero
    33
    • February 27, 2021 at 3:09 AM
    has already been done in the single axis master method and continues with the problem
  • Nation
    Typical Robot Error
    529
    1,910
    • February 27, 2021 at 3:43 AM
    Why are you putting your posts in code blocks? This takes more work than posting normally.
    Sounds like you might have the wrong arm model loaded. That, or the wrong ratio gearbox was installed.
  • Nicolas Romero
    33
    • February 27, 2021 at 4:05 AM
    only axis 2 gerbox han been changed
    axis 6 is the one that is not following the linear movement in the word coordinate
    today the robot customer informs me thar they have never mastered the robot , I come from factory mastered with the fixture position master method
  • TOOL
  • coordinate
  • REDUCER
