Program Password Protect Fanuc R30iA Controller
  • Hello,
    I am having an issue with weld techs changing the weld schedule called in our programs so that multiple welds will be calling the same weld schedule. Is it possible to set up a user defined password that allows the techs to still make point adjustments, but block them from changing the called schedule? Any help would be much appreciated. Weld controller is Fanuc R30iA.
  • Yes, you can create a custom xml for the password protect option in Fanuc and set the features/pages the techs will have access to. When using the webpage you can go in and see what your current screen number is and then enable/disable with each user login.
