Gents, I have a problem with using SET_POS_REG instruction in Karel.
I want to set the value to PR fot example the following data:
posn.X = 0
posn.Y = 0
posn.Z = value
posn.W = 0
posn.P = 0
posn.R = 0
SET_POS_REG(reg, posn, status)
The instruction itself make a good job, but when I want to use this position as offset to points in a program, I got a problem with config field in the PR.
Before running my Karel prog, the PR config field was NUT 000, after using SET_POS_REG from Karel prog, I got "FUT 127-1-1".
My "value" is around -200.
The effect is, when using is as the offset data, I got the alarm INTP-311 Uninitialized data, which stops my robot.
Do you have any ideas how to solve that issue?
