I have a16 DI input module on my robot. How can I configure UI18 as a production start? Do I need to add more DIs?
UOP
- Gravel47
- Thread is Unresolved
What is your program selection method set to?
Other
If you are using Others, you would have a program selected that will be automatically be selected by the operating system under certain circumstances.
You just need to receive (among other UIs) UI[6:Start] to run that program.
to start from scratch. If set to false, it will resume or start an aborted program from the cursor position.t from scratch. If set to false, it will resume or start an aborted program from the cursor position.
UI[18] is still the correct way to start no matter what the selection method.
That being said, you don't need to assign DIs directly in order, you can skip around and only assign the ones needed. For example there is No point in assigning the pns bits when using Other method.
So just go into the DI config screen and set the start point and ranges for only what you need and skip the others.
