  4. Comau Robots
wnc5g
  • raynald60
  • February 17, 2021 at 9:21 AM
  • raynald60
    45
    hello
    on comao wnc5g
    is it possible to decompil by lot like decomp *.cod *.pdl and *.var *.lsv or bat file command
    i do manualy
    thanks
  • massula
    203
    8
    1,424
    • February 17, 2021 at 12:46 PM
    I'm not sure if I understood You question correctly, but You can compile / decompile more than one file at once through WinC5G.
    Open WinC5G (or WinCRC)
    1- navigate to the folder that have your files
    2 - order it by type, if necessary
    3 - select the first file, press Shift key, and select the last one.
    4 - righ-click over the selected files and click on Translate function, OR
    5 - click on Translate button in the menu bar.
  • raynald60
    45
    • February 17, 2021 at 2:07 PM
    ok thanks i will test before i do save to pc in lsv or pdl
  • raynald60
    45
    • February 17, 2021 at 2:51 PM
    ok it run
    i use this for see process arc welding information
  • massula
    203
    8
    1,424
    • February 17, 2021 at 4:08 PM
    Interesting.
    Never saw this PDL Editor on your screenshot.
    It's something You are developing?
  • raynald60
    45
    • February 17, 2021 at 6:08 PM
    send a email the link is in the picture
    the guy will repond you
  • massula
    203
    8
    1,424
    • February 17, 2021 at 6:46 PM
    I will.
    Thanks!
Users Viewing This Thread
  • 1 Guest
