BASE Frame Angle routine :
  • SU05LLY
  • February 17, 2021 at 8:44 AM
  • SU05LLY
    30
    Good morning forum,
    Tech Specs:
    KR10 - R1100 Agilus-2
    KRC4 Compact
    KSS 8.6.6
    KOP:
    SafeOperation 3.5
    RoboTeam 3.1
    ForceTorque Control 4.1
    Description:
    Running into a snag with our cell.
    The part were wanting to dock up-to is wheeled into place and we use vision to locate and offset our BASE_DATA[Calculated] ( using a 2D camera ).
    My "Problem" being, the Staubli tool changers we're using are somewhat a super interference and "accurate" fitment, and what I'm seeing is that different presentation positions / different floor area's do present varying presentation angles which are causing a headache.
    I'm being asked to software fix a mechanical design problem ( well that's what I fell at this point in time ), but in the spirit of teamwork, I'm wanting to negate as much variance as possible.
    I recall in nuclear doing BASE origin and angle calculations in the past using an inductive switch and fast measurement input (X33). Tho I didn't write this function, it worked really well, and thus wanted to ask if anyone has a piece of code I can deploy and amalgmate into my routine?. Essentially, I'm wanting to calculate the A/B/C and assign to BASE_DATA[Calculated].
    Many thanks in advance
    SkyeFire
    1,052
    9,427
    • February 17, 2021 at 5:00 PM
    You have a 2D camera (I assume X, Y, A), but your part placement error is in all 6 degrees of freedom? Yeah, that's a design error all right.
    I don't think there's any quick or simple way to do what you're attempting. This is what KUKA sells TouchSense for, and that's a non-trivial package.
    You have Force-Torque Control -- can you use that to let the robot "feel" its way into engaging the part?
    Upgrading to a full 3D-6DOF vision system would be another way to fix the problem.
    If you have to try a pure software approach with a touch probe... well, I assume you'd use the camera first to get the initial Base correction. You would have to touch multiple points, and do a lot of trigonometry to process the delta between the points "real" positions and "ideal" positions into A, B, and C corrections, then apply those to the Base. It should be possible, but it's not simple.
  • SU05LLY
    30
    • February 17, 2021 at 6:29 PM
    Hi Skyfire,
    The designers to be fair "assumed" the X/Y/A would differ between operators and how the present, but now that the tooling has come to site, the interference fitment is quite impressive from an engineered perspective ( as I guess you'd hope from a tool changer ) , but far more suited to a CMM machine sat on a granite worktop LOL!!!!....
    I was wondering if there was anything within a .SRC called FrameLib ( maybe called something similar ).
    also the design engineers are looking into compliance tool changer adaptors ( jury is out on this atm ).
    "You have Force-Torque Control -- can you use that to let the robot "feel" its way into engaging the part?"
    I have seen this is a sales promotion of this tech package placing circuit boards onto mtother boards - has anyone used this "sensor guided motion" before?.
    SkyeFire
    1,052
    9,427
    • February 18, 2021 at 5:34 PM
    Where did this FRAMELIB.SRC come from, and what does it contain? It doesn't sound like a standard KUKA file.
    There was, IIRC, an undocumented .SRC file (whose name escapes me) that used to come installed on every KRC, that contained a set of routines for creating an altered Base from a set of "ideal" points and a parallel set of "found" points -- this routine would do a 6DOF best-fit and return an altered version of the original Base that had been shifted&rotated to match the "found" points.
    The H70 package for TouchSense did this, but trying to reverse-engineer that code was a good way to go cross-eyed.
  • SU05LLY
    30
    • February 19, 2021 at 8:20 AM
    Morning Skyfire,
    I'll dig through some old customer archives I done for KUKA Systems. The nuclear jobs used a "touch sense" approach that effectively found an ORIGIN via 2 point sensing in working direction #X and #Y then used that result to do a Z 3-point top down approach to create the plain relative to the working base.
    Will report back.
  • SU05LLY
    30
    • February 19, 2021 at 8:47 AM
    SkyeFire
    Just seen this is my downloads, I'm sure in the past I downloaded this from here, never tried it, but will amalgamate into the controller and have a look at what it's doing....
    Files
    BASE_LIB.zip 1.41 kB – 49 Downloads
    SkyeFire
    1,052
    9,427
    • February 19, 2021 at 2:40 PM
    Yeah, that appears to be a program that performs the 3-point Base procedure programatically. The trick is going to be that you'll have to create your Base such that you can have 3 "touchable" points on the part, one at the Origin, one on the X axis, and one in the XY+ plane.
