Fanuc Tcp/Ip app with Karel
  • Damek123
  • February 15, 2021 at 2:38 PM
  • Damek123
    13
    Greetings,
    I want to make Python app that would communicate with Fanuc robot via TCP/IP. The goal is to select a program to run on TP.
    I believe that I need to use Karel to read data from Python app. Is it possible to get some small piece of code as an example of how to do that?
    I am totally new in Karel so it would be very helpful just to try some simple example of reading data and calling program in Karel via TCP/IP.
    Thank You!
  • hermann
    412
    2,629
    • February 15, 2021 at 10:00 PM
    There are examples in the documentation of Fanuc. See also
    Simple external HMI without PLC?
  • jmd2777
    34
    193
    • February 17, 2021 at 9:35 PM
    Damek,
    Its not a simple process. You will need to rely heavily on the Fanuc manual for Karel.
    Here is an overview:
    1. You must have Karel and User Socket Messaging software option on the robot
    2. Configure a Socket Messaging server in the Host Comm settings of the robot. Pay attention to the SERVER_PORT setting.
    3. Create the Karel program using the Socket commands. These are in the Karel manual. These will look like the following:
    sock_var : FILE
    STATUS : INTEGER
    MSG_CONNECT('S3', STATUS) --Where S3 is the Server you configured for socket messaging.
    OPEN FILE sock_var ('rw', 'S3') --Where sock_var is a variable you declared of type type FILE.
    You will also need the commands READ, WRITE, BYTES_AHEAD, and MSG_DISCO.
  • hermann
    412
    2,629
    • February 18, 2021 at 8:54 AM
    With a request.get() and the above mentioned thread it should be easier to do the task.
  • Damek123
    13
    • February 21, 2021 at 7:29 PM
    Thank You. I am currently trying to establish a connection between the Fanuc robot in Roboguide and my Python app.
    Is this even possible? I want the robot to be a client and the app needs to act as a server. Is it possible to simulate that kind of connection in Roboguide? Or it needs to be done on a real robot?
    Thank You!
  • hermann
    412
    2,629
    • February 22, 2021 at 7:37 AM
    Roboguide can do that.
  • Damek123
    13
    • February 22, 2021 at 10:37 AM
    I tried to follow this topic :
    TCP Karel Client not connecting to server
    I did everything exactly the same but I am still not able to connect to my server.
    What am I doing wrong? Do I need to adjust the client tag setup or something if I want to use Roboguide instead of a real robot?
    Thank You!
  • Damek123
    13
    • February 22, 2021 at 11:12 AM
    I managed to establish a connection. My next question is how to run the Karel program for connecting to the server and collecting data in the background? I don't want to call it from TP. I want to run it every time I start the controller. Is this possible?
  • hermann
    412
    2,629
    • February 22, 2021 at 12:54 PM
    May be Background programs helps.
  • Damek123
    13
    • February 23, 2021 at 9:56 AM
    I managed to establish a connection and run a simple program in Karel and in TP in parallel.
    But I have a problem with Roboguide. It keeps crashing every time I manage to establish a connection. Also when I run Karel script parallel with a simple TP program (movements between two points) everything starts lagging and robot movements are very slow and in big steps.
    What am I doing wrong? I attached Karel program and TP program.
    PROGRAM kc
    %STACKSIZE = 4000
    %NOLOCKGROUP
    %NOPAUSE=ERROR+COMMAND+TPENABLE
    %ENVIRONMENT uif
    %ENVIRONMENT sysdef
    %ENVIRONMENT kclop
    %ENVIRONMENT bynam
    %ENVIRONMENT fdev
    %ENVIRONMENT flbt
    %INCLUDE klevccdf
    %INCLUDE klevkeys
    %INCLUDE klevkmsk
    VAR
    file_var : FILE
    tmp_int : INTEGER
    tmp_str : STRING[128]
    status : INTEGER
    entry : INTEGER
    loop1 : BOOLEAN
    BEGIN
    label::
    SET_FILE_ATR(file_var, ATR_IA)
    SET_VAR(entry, '*SYSTEM*','$HOSTC_CFG[1].$SERVER_PORT',8000,status)
    WRITE(' VAR status = ',status,CR)
    MSG_CONNECT('C1:',status)
    WRITE(' Connect status = ',status,CR)
    IF status = 1 THEN
    GOTO label_2
    ENDIF
    GOTO label
    label_2::
    MSG_PING('C1:',status)
    IF status = 0 THEN
    MSG_DISCO('C1:',status)
    WRITE('Disconnect status=',status,CR)
    GOTO label
    ENDIF
    GOTO label_2
    END kc
    tp program:
    RUN kc
    LBL[1]
    J PR[1] FINE 100%
    J PR[2] FINE 100%
    JLBL[1]
  • jmd2777
    34
    193
    • February 23, 2021 at 3:17 PM
    • #11
    It looks like you created a loop with your GOTO statements without any DELAY in the loop. In KAREL you need a DELAY in a loop or it will take all of the CPU resources and lockup the controller. Try adding DELAY 50.
  • Damek123
    13
    • February 24, 2021 at 6:35 AM
    • #12
    Thank You, I didn't know that. However, I tried to add some delays into the code but it still doesn't work correctly.
    Every time when my loop is iterating in Karel the robot moves with lag. If I put a delay to 3000 for example, the lag occurs every 3 s. Any advice on how to solve that? (I am doing everything in Roboguide for now so I don't know if a real robot will behave in the same way).
  • hermann
    412
    2,629
    • February 24, 2021 at 7:56 AM
    • #13
    Do you have only one delay in your code? Where exactly.
    Post your actual code. Should look like:
    ....... blabla ...
    BEGIN
    label::
    delay 50
    IF status = 1 THEN
     GOTO label_2
    ENDIF
    GOTO label
    label_2::
    delay 50
    IF status = 0 THEN
     GOTO label
    ENDIF
    GOTO label_2
    END kc
  • Damek123
    13
    • February 24, 2021 at 8:05 AM
    • #14
    PROGRAM kc
    %STACKSIZE = 4000
    %NOLOCKGROUP
    %ENVIRONMENT uif
    %ENVIRONMENT sysdef
    %ENVIRONMENT kclop
    %ENVIRONMENT bynam
    %ENVIRONMENT fdev
    %ENVIRONMENT flbt
    %INCLUDE klevccdf
    %INCLUDE klevkeys
    %INCLUDE klevkmsk
    VAR
    file_var : FILE
    tmp_int : INTEGER
    status : INTEGER
    entry : INTEGER
    loop1 : BOOLEAN
    s : STRING[25]
    BEGIN
    label::
    DELAY 100
    DELAY 100
    IF status = 0 THEN
    WRITE(' spojeno',status,CR)
    DELAY 100
    WRITE(' Odspojeno',status,CR)
    ENDIF
    DELAY 100
    GOTO label
    END kc
    Yes, I tried with a few delays but I still get the same behavior.
  • Damek123
    13
    • February 24, 2021 at 12:23 PM
    • #15
    Here is the full code. The idea is that the Karel program works in the background and on the Python app demands changes DO and get register values. I tested locally and everything works. The problem is only that when I run simultaneously Karel and TP program (a simple program that moves the robot through few points) the robot in Roboguide starts lagging and moving in big steps. I tried with a few delays but that didn't help. Any other ideas?
    Thank you!
    PROGRAM kc_test
    %STACKSIZE = 4000
    %NOLOCKGROUP
    %ENVIRONMENT uif
    %ENVIRONMENT sysdef
    %ENVIRONMENT kclop
    %ENVIRONMENT bynam
    %ENVIRONMENT fdev
    %ENVIRONMENT flbt
    %ENVIRONMENT REGOPE
    %INCLUDE klevccdf
    %INCLUDE klevkeys
    %INCLUDE klevkmsk
    VAR
    file_var : FILE
    tmp_int : INTEGER
    status : INTEGER
    entry : INTEGER
    loop1 : BOOLEAN
    broj_kom : INTEGER
    status_2 : INTEGER
    broj_kom_str : STRING[128]
    r_val : REAL
    rflag : BOOLEAN
    BEGIN
    label::
    DELAY 100
    loop1 = TRUE
    IF status = 0 THEN
    WHILE loop1 = TRUE DO
    DELAY 100
    WRITE('Opening file...',CR)
    OPEN FILE file_var('rw','C1:')
    status = IO_STATUS(file_var)
    IF status = 0 THEN
    WRITE('Waiting to read from server...')
    DELAY 100
    READ file_var(tmp_str::2)
    WRITE('Read: ',tmp_str::2,CR)
    DELAY 100
    IF tmp_str = 'P1' THEN
    FOR tmp_int = 1 TO 18 DO
    DOUT[tmp_int] = OFF
    ENDFOR
    DOUT[1] = ON
    DOUT[5] = ON
    DELAY 500
    ENDIF
    IF tmp_str = 'P2' THEN
    DOUT[tmp_int] = OFF
    ENDFOR
    DOUT[1] = ON
    DOUT[6] = ON
    ENDIF
    IF tmp_str = 'P3' THEN
    DOUT[tmp_int] = OFF
    ENDFOR
    DOUT[1] = ON
    DOUT[7] = ON
    ENDIF
    IF tmp_str = 'P6' THEN
    DOUT[tmp_int] = OFF
    ENDFOR
    DOUT[1] = ON
    DOUT[8] = ON
    ENDIF
    IF tmp_str = 'P9' THEN
    DOUT[tmp_int] = OFF
    ENDFOR
    DOUT[1] = ON
    DOUT[9] = ON
    ENDIF
    IF tmp_str = '12' THEN
    DOUT[tmp_int] = OFF
    ENDFOR
    DOUT[1] = ON
    DOUT[10] = ON
    ENDIF
    IF tmp_str = 'S6' THEN
    DOUT[tmp_int] = OFF
    ENDFOR
    DOUT[1] = ON
    DOUT[11] = ON
    ENDIF
    IF tmp_str = 'S9' THEN
    DOUT[tmp_int] = OFF
    ENDFOR
    DOUT[1] = ON
    DOUT[12] = ON
    ENDIF
    IF tmp_str = '13' THEN
    DOUT[tmp_int] = OFF
    ENDFOR
    DOUT[1] = ON
    DOUT[13] = ON
    ENDIF
    IF tmp_str = '14' THEN
    DOUT[tmp_int] = OFF
    ENDFOR
    DOUT[1] = ON
    DOUT[14] = ON
    ENDIF
    IF tmp_str = 'F6' THEN
    DOUT[tmp_int] = OFF
    ENDFOR
    DOUT[1] = ON
    DOUT[15] = ON
    ENDIF
    IF tmp_str = '15' THEN
    DOUT[tmp_int] = OFF
    ENDFOR
    DOUT[1] = ON
    DOUT[16] = ON
    ENDIF
    IF tmp_str = 'F9' THEN
    DOUT[tmp_int] = OFF
    ENDFOR
    DOUT[1] = ON
    DOUT[17] = ON
    ENDIF
    IF tmp_str = 'CO' THEN
    DOUT[tmp_int] = OFF
    ENDFOR
    DOUT[1] = ON
    DOUT[2] = ON
    ENDIF
    IF tmp_str = '99' THEN
    DOUT[4] = ON
    CLOSE FILE file_var
    GOTO label
    ENDIF
    IF tmp_str = 'BR' THEN
    GET_REG(1, rflag, broj_kom, r_val, status_2)
    CNV_INT_STR(broj_kom, 0, 0, broj_kom_str)
    WRITE file_var(broj_kom_str)
    CLOSE FILE file_var
    ENDIF
    IF tmp_str = 'RS' THEN
    SET_REAL_REG(1,0, status_2)
    DELAY 50
    CLOSE FILE file_var
    ENDIF
    CLOSE FILE file_var
    ELSE
    GOTO label
    ENDIF
    ENDWHILE
    ENDIF
    DELAY 200
    GOTO label
    END kc_test
  • jmd2777
    34
    193
    • February 24, 2021 at 3:44 PM
    • #16
    Its possible that its just the graphics lagging in Roboguide.
  • Damek123
    13
    • February 25, 2021 at 6:25 AM
    • #17
    Quote from jmd2777
    Yeah, I think so too. I will test it soon on a real robot.
    Thanks!
  • lemon132
    14
    • July 19, 2021 at 9:42 AM
    • #18
    Hello, may i ask if you tested on a real robot ?
  • echolinq
    • January 18, 2022 at 5:07 PM
    • #19
    I don't think there is anyway to do it "out of the box". I think you would have to use the socket messaging option and implement TCP/IP on your own. They way I have done it in the past is use a library that implemented Ethernet/IP messaging and communicated directly to the robot that way. I didn't use python but I have used C# and C++. I'm sure there's probably a python library out there.
    c# implementation:
    https://github.com/rossmann-engineering/EEIP.NET
  • Uli202
    • June 25, 2025 at 10:27 AM
    • New
    • #20
    Hey,
    I really dont want to seem like advertising FANUC product, but I can highly recommend you to get RMI option from fanuc. RMI (Remote motion interface) is based on TCP/IP, written in python and has everything built in which you are looking for and even more. It is definetly a great add on.
    I believe there is a some also some code examples. Just checkout this source:
    Files · 3270afdd02f1414775b396f532a32e92d4d705ff · Diego Tognelli / fanuc_rmi_ros_node
    ROS node that implements Remote Motion Interface (R912) protocol for communication between ROS and the Fanuc Robot.
    gitlab.cblelectronics.com
Similar Threads
  • Running robot from c# app using PCDK
    • G05U
    • November 12, 2018 at 7:12 PM
    • Fanuc Robot Forum
  • Lincoln i400
    • Joshua460
    • September 18, 2018 at 5:14 PM
    • Fanuc Robot Forum
  • tp
Users Viewing This Thread
  • 1 Guest
