Hi, using the IRC5 (RW 5.x), and I have the FTP Option. If I transfer the "COREJOBS" directory, is that sufficient for restoring my controller/programs if there is a problem?
FTP Option question
netmatt -
February 12, 2021 at 7:33 PM -
I have not heard of the COREJOBS directory before, but if you wish you restore your controller back to a previous state you must first create a backup using the FlexPendant. ABB Icon>Backup and Restore
OK, this must be their chosen location to put the backup into. So if I run the backup and restore function and put the backup into that directory, I can then grab it via FTP, it sounds like.
Yes, you will be able to FTP it off along with the other files. In the event that things get really messed up with your system you will need to use the restore function with that backup ONLY, not the other files that you retrieved.
