Hello everyone,
I am a new kuka user, ı was use abb and kawasaki robot but ı use kuka first time, first time ı need support. What do you recommend? Where would ı start? pdf or another thing
thanks in advance.
"kuka kr16 r1610"
Hello everyone,
thanks in advance.
"kuka kr16 r1610"
Check out the manuals and tools section of the forum and get an "Operating and programming integrators manual" and have a read, should give you more than enough to get started. You should have also got a usb with a set of documents with the robot. These manuals will be linked to the KSS version of the robot controller which is the "Kuka System Software", you can check which version your robot is currently running by going to the robot pendant and going to the "Help -> Info" screen so make sure you get the corresponding manual.
It will of course be useful to have some sample KRL (Kuka robot language) programs to look at also while going through the manual so do a search on the forum for some. There is already a wealth of code samples and snippets here that you could reference.
where did you start using abb or kawasaki?
The very first thing you have got was probably some basic training courses and documentation
With kuka it is actually the same
support you will find in kuka documentation, this forum here or suppport directly from kuka
