TOUCH SENSE INSIDE FANUC ROBOGUIDE WELDPRO
  • sanjay bisht
  • February 10, 2021 at 4:53 AM
  • sanjay bisht
    85
    Team - I saw some videos on YouTube where they are demonstrating the touch sensing inside software , do anyone know what I need to setup inside WeldPro to get touch sensing or laser sensing functional ???
    We probably have to insert the part differently inside WeldPro and add some add in drivers but no idea about how...
  • dha
    28
    397
    • February 12, 2021 at 11:50 AM
    Touch Sensing in RG works thru collisions.
    First you enable collisions on robot to trigger robot input and then in MENU -> Setup -> Touch IO you set this RI as Touch sensing trigger.
    You also need to enable collisions on positioner, workpiece, ...
  • tomorrowli
    • April 16, 2021 at 4:00 PM
    Quote from dha
    Excuse me, I've been busy for three days and it's prompted that I can't find the parts and crashed. Can you take a screenshot to illustrate how to set it up? thank you very much
  • aba3210
    • October 31, 2024 at 7:25 AM
    Same problem here! I have a CRX10iA arm, the Collision Guard enabled, and the 'Show robot collisions' option activated in both, the arm and the object. I have written a small program for the robot to do a small search using the Touch sensing. However, it's not stopping when it collides against the object.
    This is my Touch I/O Setup:
    • Touch Sensing type: Wire Touch.
    • Sensor port type: RI.
    • Sensor port number: 1.
    • Circuit port type: RO.
    • Circuit port number: 1.
    And my program is this:
    1. COL DETECT ON
    2. J P[1] 100% FINE
    3. Search Start [1] PR[3]
    4. J P[2] 100% FINE
    5. J P[3] 100% FINE Search[X]
    6. Search End
    7. J P[1] 100% FINE
    Any help that you could provide would be great. Thannk you in advance!
  • dha
    28
    397
    • November 12, 2024 at 11:07 AM
    Did you set RI as Collision IO in robot's property window?
  • aba3210
    • November 18, 2024 at 7:24 AM
    That was exactly the problem, now it's working perfect, thank you so much!
  • robertoaferrari
    • April 7, 2025 at 4:13 PM
    Thank you so much guys! this is realy amazing, a did a course in FANUC Brazil and they dosen't have this information to share to us!
Users Viewing This Thread
  • 1 Guest
