KSS01323 Invalid specification
  • evo85210
  • February 8, 2021 at 9:06 AM
  • evo85210
    63
    I'm running a simple test code on a KR60 (8.3), but the src file won't copy into the R1 folder, it gives me a KSS01323 error
    Quote
    out Invalid specification
    {Path} Invalid specification
    Effect
    No braking reaction
    No interlock of motions or commands
    The program i'm trying to run is as below
    &ACCESS RVP
    &REL 1
    DEF Do()
    ;DAT DECL
    DECL FRAME DefaultTool
    DECL FRAME DefaultFrame
    DECL REAL DefaultSpeed
    DECL REAL DefaultZone
    ;INI
    DefaultTool = {FRAME: X 0,Y 0,Z 0,A 0,B 0,C 0}
    DefaultFrame = {FRAME: X 0,Y 0,Z 0,A 0,B 0,C 0}
    DefaultSpeed = 0.1
    DefaultZone = 0
    BAS (#INITMOV,0)
    $ADVANCE=5
    $APO.CPTP=100
    $TOOL=DefaultTool
    $LOAD.M=0
    $LOAD.CM={X 0,Y 0,Z 0,A 0,B 0,C 0}
    $BASE=DefaultFrame
    ;START PROG
    PTP {A1 30.2184,A2 -88.5401,A3 95.1721,A4 -101.2155,A5 30.8703,A6 13.008, E1 0, E2 0}
    $OUT[36] = FALSE
    $VEL.CP = DefaultSpeed
    $VEL.ORI1 = 180
    $VEL.ORI2 = 180
    LIN {X 1012.401,Y 80.21,Z 1539.471,A 90,B 0,C 90, E1 0, E2 0}
    $OUT[36] = TRUE
    LIN {X 1009.455,Y 1066.391,Z 454.152,A 90,B 0,C 90, E1 0, E2 0}
    $OUT[36] = FALSE
    END
    If I add approximation to the movement, it'll work fine.
    can someone tell me what the issue is?
    thanks
    panic mode
    1,293
    13,122
    • February 9, 2021 at 2:09 AM
    • Best Answer
    message is not very clearly worded but it can be argued that sort of points in the right direction - your program is invalid...
    it does not follow KUKA naming convention which dictates maximum length for a name, set of characters that are ok etc. in your case issue is violation of reserved word (key word). you cannot have variables programs or anything else declared as some keyword like LIN, PTP, INTERRUPT, DO, WAIT etc.
    if you try to create such file name on the robot, using smartPad, or if you try to import program with space in the name etc usually message KSS03158 is displayed (inadmissible module name).
