Fanuc position
  • moelsayed
  • February 6, 2021 at 3:12 AM
  • moelsayed
    98
    I would like to understand the below point:
    - For example I set robot on specific Uframe= 1 & ToolFrame =2 then I did touchy to record current position in PR[20].
    - so when I pressed on [POSN] button on TP I got values for XYZWPR .
    My question is these are these values relative to My selected frames? ?
    Question 2- I found in the dames PR[20] screen UF:F UT:T what is that???
    Thank You,
    Elsayed
  • HawkME
    568
    10
    3,268
    • February 6, 2021 at 4:25 AM
    They are taught in the current frame, UF=1, UT=2. But PRs will adapt to any frame.
    So if you switch frames and move to that PR it will now be relative to whatever the current frame is. Best practice is to always set the UF and UT before motion so it is always in the frame you intended.
Similar Threads
  • Error SYST-034 HOLD signal from SOP/UOP
    • kicaj073
    • May 18, 2018 at 8:24 AM
    • Fanuc Robot Forum
  • FANUC teaching pendant need help writing code
    • CindyShouts26
    • February 4, 2021 at 9:06 AM
    • Fanuc Robot Forum
  • need HELP writing a simple FANUC syntax instructions for the teach pendant
    • CindyShouts26
    • February 4, 2021 at 8:09 AM
    • Fanuc Robot Forum
  • Oil change of M16İ robot
    • byrol
    • January 26, 2021 at 7:09 PM
    • Fanuc Robot Forum
  • Deviation in position between RoboGuide and real robot
    • fmiroslav
    • January 12, 2021 at 9:50 AM
    • Fanuc Robot Forum
  • Motion 063 error (cr15ia Fanuc robot)
    • Jerryl859
    • January 19, 2021 at 12:21 PM
    • Fanuc Robot Forum
  • Reference position/position register
    • Jerryl859
    • January 18, 2021 at 1:06 AM
    • Fanuc Robot Forum
  • FANUC Robot R-2000iB 210F and controller iC for R2000iC/125L
    • Taes
    • January 14, 2021 at 9:35 AM
    • Fanuc Robot Forum
  • HELP
    • Kawazaki02
    • January 6, 2021 at 2:58 PM
    • Fanuc Robot Forum
